running lean?
fred79
pittsburgh
I was delivering with my sho today and running on the highway in third gear at near WOT I got a check engine light it stayed on for about a min. and then went off. I ran the codes and got a 172, 176, 211,542. I am pretty sure that the 211 is left over from when I changed my cps and the 542 I think is from stalling on a steep hill today from a start. so I think the lean code is what caused the CEL. now I was try to listen for a vacuum leak and the intake noise sems high but that might just be me. haven't had a CEL from anything since I changed CPS. I will try to clear it and keep watching. I have noticed my engine losing power between 3-4000 rpm but I was attributing this to the crap clutch job my local shop did and it usually reves above and just loses momentum, but I have also noticed the engine holding rpms and just stumbling. I also have a plug well oil leak so I figured it was oil in the cylindar. but with a lean code that wouldn't make sence, also I have noticed a gas smell from the exhaust at times. so the car has me theroughly confused. I am going to try a KOER compression test.
DHMag
Free At Last
InCahoots, Texas
looks to me like your O2 sensors are bad, according to the codes you listed. id say reset the codes then pull em again.
fred79
pittsburgh
I reset and pulled again and got nothing so I will keep driving and hope if there is a problem it willl show it self again. the balance test proved ok.
