running hot
MGidish
San Antonio, TX, USA
All of a sudden my car started overheating. I replaced the T-stat and it still runs hot. I'm getting beckpressure (steam) coming from the tubing right above the T-stat location and can hear the coolant gurgling. I don't see any leaks around the water pump so is it the radiator?? Thanks in advance.
TYSHO
Earth
Check your coolant level. Is it low? If so, check your hoses for slits or loose connections, which can cause for a small leak. Over time it'll cause over heating from the loss of fluid and air in the system.
