rubbing/grinding sound 91 plus
shoboy1992
iowa
I have 91 plus my wheel bearing in the front went bad so i went and got a replacement and had it pressed. I put everything back together and now i have a rubbing/ grinding with a squeaky sound coming from the same side if im doing over 60mph there is no sound but its loudest when im doin 10 to 30 mph i would love if anyone had some ideas on what it could be cuz im stumped.. i feel it in my brakes and a little bit in the steering wheel. Plz help
1320n2oSHO
California
Start by jacking the car up and spinning the the wheel see if it spins freely and easily also if its making noise you'll be able to tell where the sound is coming from. Another thing to do is grab the wheel at 12 o'clock and 6 o'clock and push/pull to check for play. That's where I'd start
and remember that just cause you had someone press in the new bearing does not mean that they did it properly and did not ruin the new bearing, so don't assume that the new bearing is good.
AREA 91
PA SHO SHOP
Area 91
It could also be as simple as the dust shield/backing plate rubbing the rotor.
