*********rod shifter******
SHO Off
Winnipeg, Manitoba, Canada
As for the pricing... they vary I believe from around 200-300 US... and some include bent resonator pipe, most dont though...
As for install and etc issues... check out this link the instructions you get when you had bought it new from Ford Motorsports.
http://www.shotimes.com/SHO4rodshifter.html
http://come.to/shocw
14.9 @ 94 mph
91 SHO plus Black
Police Grill, Rod shifter, Strut tower braces. 80mm MAF, SHOshop CAI, UDPs, SHOshop LPM, Big Bore Butterflies, Ported Intake Runners, Port match enite Intake Manifold and Intake ports on Heads,Dynomax cat-back w/2.5 inch tips exiting through bumper. Painted SHO lettering Yellow. Homemade Shorty SFCs, Alum SFBs.
Ypipe on Order!
"SHO OFF" Plates
80 Camaro
325 hp 350 ci. Custom Paint, wheels. Shift kit and all those goodies.
1slickRED89
Guest
Toledo Ohio
this is not my original idea but rodshift mechanism on the escorts and tempos are very similar in design to the Rodshift in my buddys 92. the ****** shiftshaft is about 32" long if i can remember right, the conection is the same too.
somebody W/rod measure to see if a taurus rod shifter shift-shaft is 32" long.
Corey
89SHO
1slickRED89
Guest
Toledo Ohio
is nobodys going to measure their rodshifter for the good of the cable-shift kind?
Corey
89SHO
1slickRED89
Guest
Toledo Ohio
do the Escorts have MX5 stlye mtx's(bolt pattern, etc.)? i know that tempos do, but i'm not sure of the escorts. I had a hard time finding info on the net.
thanks everyone. any mesurements of the shifter yet, please.
Corey
89SHO
1slickRED89
Guest
Toledo Ohio
could somebody please measure the length of the rod shiftshaft on a Taurus and post it. thank you
forget about the ****** thing. ford lists the parts individually anyhow, the parts are obsolete to boot! oooo well.
Corey
89SHO
i promise i'll let this thread die if a kind soul will post an accurate mesurement, honest.
