Right Side headlight
shotime99
Michigan, Metro Detroit
Couple of ?'s........(please save the "your stupid" comments till the end of your replies)
How do i remove and install a headlight on the pass. side of my 99 SHO? My hand are way too fat to reach in that little hole and the coolant resivoir is right behind it..
Why would my r headlight be SUPER dim suddenly. I would think that if the headlight were bad, it would just burn out completely, not partially. I checked the fuse, it's fine. Tried the hi beams, no difference.
Sorry if the questions are stupid.....
Take the whole headlight out. Three 10mm bolts and then one pinch bolt in the back.
Sounds like a bad ground or burnt connector. Get a headlight relay harness it will make it all better.
