Replacing the heater core....
93mtx
Saginaw, MI
I am looking at picking up a 95 atx (cheap)...but it needs a heater core. What kind of project am I looking at getting into? How long? How Hard? What kind of cost am I looking at? I assume the dash has to come out, right?!?!
Shoaz
Studly dood
Scottsdale, AZ
IMHO that's one of the worst jobs on a SHO. The heater core was the first thing to come down the conveyor belt on the Taurus assembly line and the car was built around it.
It's doable, but it's a crappy job. Use that as leverage to negotiate the price.
Phoenix
SHOHOLIC
QC , Canada
If you're mechanicly inclined , its just long. Because of the dash. The core itself is pretty cheap , it's the job that scares people off. I think theres a how-to over here , do a little search.
93mtx
Saginaw, MI
I have taken the dash out of my brother's fox body to replace that heater core. Easier than harder than that? Anything else to look for if I do it?
AREA 91
PA SHO SHOP
Area 91
There is a write up in the "how to" section on the forum.
It helps a lot.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
:shrug: I find it alot easier than anything else to do. I can do them in about 2.5 hours. If you're a novice, maybe a day in and out. You do have to evac & recharge the AC though. Oh, replace the BDA while you're there.
- James
93mtx
Saginaw, MI
I am not a novice but I haven't ever done this particular job before. Well I its worth going and taking a closer look at. Thanks for all the help.
jpSHO
Massachusetts
I just did the heater core in my 95 ATX. If you like A/C I would do the A/C evaporator too while the dash is out. It wasn't too hard but time consuming. The hardest part was getting at all the bolts in the engine compartment firewall. The dash doesn't have to come completely out just enough to get the evaporator housing out.
93mtx
Saginaw, MI
That's good to know. I am going to look at the car tonight we will see then if it is worth it or not.
crystizel
