Replacing struts...
Bryan
What do you get when a deer & SHO cross at 45mph?
Morgantown PA
So I am about to replace the struts on my 92 SHO and I am wondering for the rear What is the best (least frustrating) way of removing them? Through the trunk or taking out the back seat is a couple options I have seen.
sperold
Last to Know
Out through the bottom.
I seem to remember there could be 2 different lengths of struts, and the long ones result in a very high rear stance, but it is kind of foggy.
If you have the right tools for tight spaces you can just do it from the trunk. I only went through the rear package tray area when I was working on the big nut from the strut to the rubber mount. You can do that with the whole assembly removed from the car though. I think I purchased tools to fit the tight space for the job last time. Been a while.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
get in the trunk with a good assortment of 13mm ratchet wrenches.
when installing, it helps if you cut the top of the studs off, just the tip that isn't threaded. that gives you more room to get the wrench on/off.
there is a trick to getting the big center nut off while in the car, if the top of the strut is a 10mm hex. I don't have a double-D socket for some after market struts.
I used a 13/16" x 1/2" drive sparkplug socket. the kind with a hex end on top. bored the center of that socket out so a 3/8" extension would pass thru it, removed the rubber plug.
that top nut can be several different sizes, I have a mutilated 7/8" deep socket in my arsenal.
Sears has some sockets with 6 tangs inside instead of a 6 or 12 pt.. a single socket fits a range of several sizes and might work well here, if you modify it as needed.
put a 3/8 drive 10mm socket on the top of the strut, put the sparkplug socket over that, pass a short 3/8 extension thru the spark plug into the 10mm.
hold one and turn the other.
or do it the easy way with an impact driver. hopefully it won't spin the shaft violently enough to damage the struts internals.
once the strut is removed you can whittle away and remove enough lead, (yes, that big thing is lead) from the vibration damper to allow a goose-neck wrench on the nut.
have fun.
Bryan
Morgantown PA
Do I need to remove the big nut? I got a complete set of loaded struts complete with a new coil spring.
Bryan
Morgantown PA
Ah okay that's good. RockAuto had some great prices on loaded struts. Most retailers around me (autozone, advanced auto, napa) ranged around 150-180 for a complete loaded strut. Moog, Koni, and another brand (forgot the name) but that's what they wanted. Crazy considering RockAuto had the same and only wanted between 80-100 for the same thing.
itwonder
VA
You can get to all of the nuts from the trunk.. a bit tight, but there's room if you get the fabric and insulation bits moved aside. There's no need to take the big center nut off to remove the strut. Depending on the replacement strut assembly, installation can be more frustrating than removal if it has longer studs on the top plate than the original. Starting the nuts before pushing the strut all the way up and home can help, if you run into that.
