When replacing the CV shafts, is it typical to have to disconnect the knuckles? I can't really see a way to shoe-horn them on without taking them off.
...properly torque the lower control arm (ball joint) (18mm, 40-55 lb-ft), tie rod end (18 or 19mm, 25-35 lb-ft), sway bar link (18mm, 35-48 lb-ft), hub nut (30mm, 180-200 lb-ft), ABS sensor (10mm, 40-60 lb-in), brake caliper pins (Gen I: 18-25 lb-ft) and lug nuts (80-105 lb-ft).
Devin said:Speaking of torque... the bolts that hold on the half shaft are a mystery. The only thing I could find in my Chiltons was reference to a "halfshaft link bearing" and it's torque was about 40 ft lbs. They are only 10mm but I do want to get them correct so my halfshaft doesn't come loose and destroy itself.
