Is the radiator cooling fan running? At all?
There is enough coolant. I think the same things-either bad water pump, or like you said, a block somewhere in the hose or something. I don't really know how to check either of those.SHOZ123:
If you aren't getting any heat out of the heater and the temp gauge is above the first line then there either isn't enough coolant in the system or the water pump isn't pumping it or there is a major clog in your block cooling system.
It sounds like we might have the same problem. I decided that the noise I'm hearing is related to the overtemp. When I run the codes I get ECT and IAT sensors out of range. You should try the diagnostics, http://dalidesign.com/hbook/eectest.htmlChrisR:
The t-stat did NOT have a jiggle valve. I used the one that shofear92 said to use (Napa p/n 219). I don't think it's just the guage, because the engine is really hot to the touch as well. This is still a mystery. I might have to take it into a shop and get a diagnosic test run, and let them figure out what the problem is.
I know this may sound crazy but check your Alt. I was having all sorts of heating problems (and an engine squeal) too and after I changed out a weak Alt everything was fine. Any auto parts store can check it quickly and for free. You may want to try a radiator flush "just in case" someone did add stop leak. Might get lucky and flush out a clog.unterhausen:
I think the dealer charges me $80 for the same thing.
