Removing fossilized paper gaskets from Intake
nomov8sho
Junkyard Rat
Phoenix, AZ
Hey all-
I figured I throw this out there in case it can help somebody else. I just finished removing the remains of the paper gaskets from my intake runners and Butterfly assemblies. My best guess is somebody had put them on with that spray-on gasket adhesive.
I started with a scraper- no dice.
Wire wheel- Nope, the gaskets seemed to be harder than the aluminum.
Soaking in brake cleaner, carb cleaner, parts cleaner- all showed some improvement but not much, and the fumes were not friendly.
Finally, out of desparation, I tried test spots of various other garage chemicals.
My best results were with P-B Blaster. It wasn't great, but it did soak in and let me lift most of the stuck areas pretty well with a razor blade gasket scraper. The areas around the bolts required some repeat applications and additional soak time. I spent about 15 hours on the job, all told. I'm guessing it might have taken 2 or 3 hours if I'd known the P-B Blaster trick from the start.
Of course, your results might vary, etc.
Hope this helps somebody out.
Thanks,
-Josh
AREA 91
PA SHO SHOP
Area 91
I try to get them off in big pieces with a fresh razor blade.
I also have a glass bead cabnet for back-up.:angelnot:
Airborne
I am glad I read this post before doing some maintenance yesterday. Oil pump gasket was "fossilized". It cut the time down considerably.
Spring Hill, FL
Oh man, this brings back bad memories of the few days I spent scraping intake gaskets a while back, WD-40, gasket remover, gasket scraper, ugh. What finally worked best was me taking a razor blade in hand and just being really careful and making sure I got under the gasket material, but still night after night of trial and error, makes it a hundred times worse when it's your daily driver.
thundersho
omaha
I just did this and what a pain in the ass.... I just used a straight razor to remove and. Figures are sore but hey its done. what turned out to be just painting the intake turned out being gaskets and 3/4 of a 60k. love my car, love my car, love my car...
chrism3784
West Palm Beach, Florida
Yep. I was just going to post that as I was reading. You beat me DIE GRINDER always works and makes a perfect surface for a new gaskets. It shaves of a microscopic amount of metal so don't go over it to many times.
Airborne
These work great too. Also, you have to be careful about removing metal, but removes less than sand paper. I have these at home. I wish I had brought them out with me. Not really that expensive to buy, but I didn't have my die grinder out here. But the PB Blaster worked in a pinch.
http://www.levineautoparts.com/3mro3meyebrd.html
itwonder
VA
I've been using those 3M Bristle discs for years, and I concur that they are very good. I'm also a big fan of the 3M Roloc Surface Conditioning Discs, both Blue (fine) http://www.levineautoparts.com/3mrolsurcond2.html and maroon (medium) http://www.levineautoparts.com/3mrolsurcond1.html
chrism3784
Today had this exact problem, the fossilized paper gasket between the oil pump and block. What I used is of course a die grinder with super grit sanding block just to get it started, then a medium grit pad and a scraper going back and forth. Pain in the ass but worked.
Airborne
You wouldn't think it, but removing that old oil pump gasket is a B**CH!
itwonder
VA
NAPA/Permatex gasket remover can be helpful too.
If it's carbonized oven cleaner will work great and not harm the metal.
Off Road SHO
Moderator
EZ-Strip paint stripper works well if you have it laying around. Also used old brake fluid one time on an old chevy.
Tom
