nomov8sho
Junkyard Rat
Hey all-
I figured I throw this out there in case it can help somebody else. I just finished removing the remains of the paper gaskets from my intake runners and Butterfly assemblies. My best guess is somebody had put them on with that spray-on gasket adhesive.
I started with a scraper- no dice.
Wire wheel- Nope, the gaskets seemed to be harder than the aluminum.
Soaking in brake cleaner, carb cleaner, parts cleaner- all showed some improvement but not much, and the fumes were not friendly.
Finally, out of desparation, I tried test spots of various other garage chemicals.
My best results were with P-B Blaster. It wasn't great, but it did soak in and let me lift most of the stuck areas pretty well with a razor blade gasket scraper. The areas around the bolts required some repeat applications and additional soak time. I spent about 15 hours on the job, all told. I'm guessing it might have taken 2 or 3 hours if I'd known the P-B Blaster trick from the start.
Of course, your results might vary, etc.
Hope this helps somebody out.
Thanks,
-Josh
Thanks,
-Josh
