removing belt tensioner
svtC_and_SHO_Owner
Oregon
which one? do you mean the timing belt? or acc belt? if its the accesory belt tensioner, then there should be 3 bolts holding the braket in place. however to untension the belt you use a allen wrench. there is a tensioner for each belt(2). i belive the back one is reverse thread you can turn it the same way as the front one to losen the belt.
