Johnlemon
So the idler pulley between the power steering pump and ac compressor suddenly locked up and shred apart the drive belt. I try to remove the pulley but there is not enough clearance between the frame and the engine to get the bolt out, about an inch higher and I can possibly take it out.
Any safe way of removing it?
and another question
my valve cover is leaking, if the gasket is fine, is it reusable?
