Removing ABS.
93rev2sev
Hockeytown
This other thread got ME thinking...I know...Don't hurtmyself...
http://www.shoforum.com/showthread.php?t=75789
Is seems like it would be easier just to completely remove ABS from the picture.
Can't you just plumb new lines from the master cylinder to the correct flex hoses...taking the ABS system completely out of the picture?
ABS is no good anyway.
1993MTXSHO
Its a Taurus...
Jersey
you could just pull the sensors outta the wheels I think. 2 or 3 of mine are bad and my tires lock like its got no abs every time i slam the peddle to the floor.
Can prolly just unplug the abs computer too but thad throw a code.
Storm-Chaser
Shit Louis
Why?
While the ABS system might do little in a straight-line, dry pavement panic event - a properly operating ABS system provides considerable braking improvement during panic events where you're trying to steer-around an obstacle while braking, or on wet roads, in loose gravel, non-paved areas (grass), etc.
But probably the biggest benefit, is your vehicle insurance. Antilock braking can result in up to a 10-percent discount.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Well, I gotta get a ring on my drivers side half shaft, and until I get over 25 mph, my ABS is working. There is a BIG difference after the light comes on. Almost feels like twice as much force is applied to the pads. Is that normal?
Storm-Chaser
Shit Louis
Eric,
I'm not sure I understand your ABS problem. Which light are you referring to, the ABS light or BRAKE light? Also, by twice as much force, that you get twice the braking effectiveness for the same amount of pedal pressure? How do you know your ABS is working over 25mph?
