Redline PTU fluid
Lol I don't know if it's fancy but I definitely won't have a fluid related failure.
One would hope. I am not as crazy as you my friend. However, you are pushing alot harder.
diego d
Etobicoke (Toronto), Canada
Can someone please tell me what happened when they got a PTU Fluid change at their mechanics? I do not work on my car much.... is the mechanic going to be smart enough to wrap the O2 sensors and Downpipes with aluminum foil while doing the job or should i tell him to myself ??
I would tell them about the aluminum foil honestly.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Hmmm I've changed the fluid twice myself, will be the 3rd time today. I have never wrapped anything. I don't even recall worrying about it or getting a bunch of oil everywhere. Sucking it out theres no mess. I use a hand pump and if anything I get the pump leaking slightly, when full there's a tiny bit of dribble. I even over filled the PTU on purpose to flush out all of my old Royal Purple 75w140 and even then I don't recall a horrible mess requiring much clean up.
802SHO
I'm definitely not smart enough. I've never wrapped anything
What's the matter? Pushing too many pencils and that drain plug you speak of
Gather around.....for all the people that don't know about the PTU.
You have to use a Mighty Vac (or something similar) to evacuate the fluid in the PTU, all 10-12 SHO's do not have a PTU drain plug. Off the top of my head (IIRC)... non-PP 13+ cars do not have a drain plug either.
13+ PP SHO's have a drain plug that when removed dumps fluid all over the O2 sensor and DP's, hence why we wrap them in foil or make a cardboard channel to keep things clean.
Peasant.
802SHO
Peasant.
Its like that class you didn't remember signing up for but see it on your itinerary....welp guess I learned something. Probably retain more if that hot substitute teacher was teaching....just saying.
I concur.
802SHO
Changed PTU and RDU fluid finally and collected samples for testing at Blackstone Laboratories. Using Redline Lightweight Shockproof gear oil and this sample has about 1,600 miles. Its been along for the ride for the new GH turbos, GH IC as well as a bunch of tune revision 3rd gear pulls, launched, dyno session, track runs, nitrous datalogging and track runs. And it just shifts and drives frickn lovely. Both samples looked.....clean. The PTU is the first one...its slightly darker than new fluid. The drain plug is pretty clean as I expected. The RDU fluid looks like I took a sample from the brand new bottle...its that clean. RDU drain plug is very clean. Huh...well I basically just took out new fluid but...at least I'll get a sample of some pretty harsh abuse and find out the whole truth and nothing but the truth so help me Easton! Lol Wow!1017192031 HDR 1017192031 HDR 1017192029 HDR 1017192011 HDR 1017192012a HDR
That you will my friend. I cannot take credit for the Redline suggestions however. Shodded was the one who gets the credit. I just tell others.
Gotta tell ya, I get a little nervous every time the recommendation is passed on to another member. Not that I have any doubts about the product, just that I want everything to go perfect for them LOL.
I will not suggest a product to the masses unless I have vetted it personally. Since I run my SHO exceptionally hard, if I have the confidence that product will/has held up I will suggest it. It just so happens that you have been on the money everytime with suggestions for me Shodded. I just pass the info along.
Csbbrah
Ky
I was skeptical about how much better this fluid would be, but everything that has been said about this fluid is true. I have a brand new ptu that had brand new motorcrap gear oil. Drove it for less than a week, swapped it and it performs better. So much smoother in every aspect. The car literally rolls better, if that makes any sense.
Thank you all for the persistent suggestions around the forums.
Sent from my LM-Q610(FGN) using Tapatalk
Glad it worked out for you.
defectivecyborg
