I have had this car for almost 8 years, it ran when I first got it, but it was nothing but issues, timing belt, clutch, valve cover gaskets, crank position sensor, It hasn’t been driven since I blew the transmission about 6 years ago.
I have gotten it back up to the point where it starts, but it runs very shortly, under a minute, after and will occasionally backfire when it does.
It has gotten a lot of parts and time.
Right now it has only a few faults, as they read from an innova reader;
116 coolant temperature sensor outside test limits
114 air charge temperature outside test limits
565 canister purge circuit failure
Then it lists 10? Possibly moving to keep alive memory
157 mass air flow circuit below minimum voltage
Now it is a project car that I want to get back to the glory it had when it was new. Does anyone have any ideas what I might be missing?
