rear windows
shotyme92
WOT :)
Forest City, IA
Car sat for a while in storage. Windows did work fine. Now the rear on drivers side doesn't work at all. Just makes a clicking noise and the passenger side only works with the switch on the rear door. Any ideas?
deercrusher
never running!
PA
it's either the switch on the door panel - or the motors have frozen due to sitting awhile. There is a writeup on this forum about taking apart the window motors and cleaning all of the rust and grime out and re-greasing them. In case you didn't know - you can go the the parts yard and use the window switches out of a slo model.
hawkeye18
Sorta cares
Norfolk, VA
I really should just bookmark this dang thread. It seems I link to it about once every other week.
http://www.shoforum.com/showthread.php?t=93453
Get to it! lol
Edit: You need to either take apart and clean (easy) or replace (crap-shoot) the main window switch panel as well. Corrosion is a b****. Rubbing alcohol and q-tips work wonderfully for this.
