thxone
Bugs
I am having an issue with my rear driver side window. The guy I bought the car from said it quit working. It works however I have to have my driver door open past the first notch in the hinge for it to work. I am thinking loose wire. What I did was remove both window switches and inspected them. All fine, no loose wires or burnt anything. So I played with the drivers door some more. Whatever the problem is has to do with the door. It doesn't matter if I am trying to use the window switch up front or on the rear door, I still have to open the driver door.
I am thinking it's the wires that go from the door to the fender... where that big plastic barrel is with the wires coming out of the bottom. How do I take that apart without taking off the door???? I am sure I will find the pinched or loose wire there.
