rear brake bleed problem
pete315
Long Island, N.Y.
got a problem with rear brakes. pedal feels mushy so I jacked up rear end. right rear tires stops when brake pedal pressed, left rear spins. if you really lean on pedal, the left rear will stop. I figure they needed bleeding. I only can get a trickle out of left rear when I open the bleeder valve. right side has good pressure. about a year ago, I replaced both rear calipers and hoses. do you think I have a defective hose on the left side? anything else could cause no pressure on left side? I have no leaks at all.
