rendyx
Knowing I was down about 3/4 qt of oil, I decided I'd better add a bit yesterday. So after I got home, I pulled out another qt of GTX 5W-30, and poured most of it in, checking the level of oil a couple times, so as not to go over. I was satisfied, and then went back inside. I returned about 1/2 hour later, and started the SHO. It immediately began to struggle, running a little rough, so I turned it right off, then tried again. After a moment, and a little looking around for anything obvious, I tried again, and it gradually improved. Later that night, it was fine. I may drain a small amount of oil today to see if that helps. Only other thing that's been happening lately is the idle stays up around 2000RPMs while I'm moving, and the clutch is in, which began after I put my new IAB in. I'm hoping it's just an odd conincendence, which is what a friend suggested to me. Perhaps a little too much oil, or what? Thanks guys, the SHO has me on a problem-a-thon lately! thumbs_u
<small>[ February 04, 2003, 04:25 PM: Message edited by: rendyx ]</small>
