random foglamps
tommyturbo
California
my foglamps every once in a while on the 89 will not work, but 99% of the time they work fine. Any ideas? I doubt it's a fuse, the mystery fuse I read about. So maybe a relay? Where is the foglamp relay on this?
tommyturbo
California
I don't know where the grounds are, I don't have any kind of service books, or wiring diagrams. They have been working perfectly lately. Only seem to act up if i turn the foglight switch on or off, but if I just leave the switch on, they seem to always work.
Gez89SHO
LEGO SHO
NE Philadelphia, PA
89's don't have a relay, the switch is most likely the culprit. These switches, being one year only (89's were the first SHO's, later years got a different dash) are hard to find as well.
SHOstuff
Houston,TX.
Yes. Check the switch because mine does the same thing and all I do is tap on the switch and it comes back on. So all thats telling me is to change the switch...and I have an '89 by the way.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
On my old Gen 1.. the thing that was always the problem for me was the little screw that holds the bulb in. If I kicked the bumper or wiggled the wire it would pop on.
If its both lights at the same time, I would think more so the switch or the ground in the harness there.. if its only one look in the fixture.
