Random ABS
oh_SHO
Ohio
95 MTX
~3K on all new stock brakes
The ABS seems to kick on when I am going around tight corners. When it does this I am usually going slow already so I don't think the tires are slipping at all. Also I wouldn't say that it kicks in fully, actually I am having trouble coming up with a way that the pedal feels. Almost like it starts to come on then deciedes not to then I am going to slow to make a difference. I don't think I got air in the system when I did the brakes and I did bleed them afterwards. But my brakes do feel the mushiest out of all the SHOs we own. I am going to bleed them again in about 15 min (RR LF LR RF) and check the ABS rings. I leave for college tomorrow and won't be around anyone that can help me with them for a while. I was wondering if anybody had any suggestions? Do I need to take it somewhere and have the ABS pump cycled to bleed it? Sound like crud in the rings? Faulty ABS sensor (have no light on)?
Thanks!
oh_SHO
Ohio
Slo-Sho said:
One of your rings are cracked, most likely one of the front ones.
Yep, the front passenger is cracked. I called around and seems like I can't get just the ring. Since its not detrimental I'll leave it until I decied it is time for half-shafts. Thanks for the info.
