radio problem
shoxtreme
Utah
the other day when i turned on the car i noticed that the radio was on but there was no lights. what i mean is that there is no display on the radio or the climate control lights. sometimes the display will come on for a bit then go off and sometimes it stays on the whole time i drive it. the radio still works and the climate control still works but there is no display. the display comes on when i turn on the lights but when i turn off the lights the display turns off. thanks tj
Mr Anonymous
Tire Wall
Try whacking the ICP (radio) a couple of times. If it starts working again you'll need to replace it or take it apart and try to fix the flex connectors.
loosenut
South Carolina
Mine is doing the exact same thing, started a couple of days ago. Got agressive and slapped the top of it and the lights came back on. I am probably going to take it out and check everything. Maybe it will be a loose connection somewhere. Have to get the remove tools though as I don't have them yet.
ArkanSHO
Arkansas
WHen mine did that the battery was dying, of course it didn't become intermitient, just went off until I replaced the battery. You might also look at the dimmer switch circuit as that controls the displays intensity.
