Radio dead
speedy91
West Des Moines, IA
I have a factory tape deck in my new plus. The lights work and it displays the radio numbers, but there is no sound. It does turn on and off, but neither radio nor the tape deck work. Any ideas?
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Check the harness for the speakers it is speaperate from the power harness.
92 White SHO
HiRevs Competion Clutch
SHOSHOP Engine Mounts
Koni Shocks
StrutTower Braces
UD Pullies
Awesome Sound System
speedy91
West Des Moines, IA
The previous owner said that it work right up till we got there. He put a tape in to test the deck and it just froze. I got the tape out. I can hear a little bit of feedback if I turn the volume way up so I think the speakers are working correctly.
Thanks,
Eric
Shoman594
Moderator
Lockport, IL
radio is prob dead. samething happend on my 91. it turned on and off but there was only a soft static nothing else.
Ryan
SHOcago Enthusiasts Club President
SHOcago Web site
http://www.SHOcago.com
SHOcago SHOforum.com Board
http://www.SHOforum.com/SHOcago
'94 Opal Frost MTX "Shoman 4"
'91+ Deep Jewel Green Build Date 6/91 with rod shifter
AIM "Shoman594"
To Join SHOCAGO Enthusiast Club, Please Email me
E-Mail mailto:[email protected][email protected]</A>
7020941 4985 020000C3
ericwick19
saginaw, MI
if it is ford "premium sound" or a jbl system. You have a external amp. which will cause one or all the channels to cut out. i see this alot
av8r567
Wayne, NJ
The 89-91 JBL head units with the up/down "flipper"-style volume control have electrolytic capacitors that have a 10-year service life after which they leak and damage the circuit board - unit is not repairable.
The 1992 units used better capacitors which won't leak. If you're interested in replacing it with a factory unit check out CincySHO used parts at:
http://209.217.44.39/Used%20or%20Special%20Parts.htm
Jim Ryan - Wayne, NJ
91 Plus - all white
FPS 96 brakes, Carbotech pads, LPM and 80mm MAF w/ K&N and SHO Shop can & horn, KONIs with SHO Shop linear springs, f&r strut tower braces and poly bushings all around, HiRevs Jr clutch and lightweight flywheel, underdrive pulleys, torque limiters, Cincy SHO reinforced engine mounts, Bridgestone Potenza RE730 tires (excellent), and police grille.
Shoman594
Moderator
Lockport, IL
Very informative Jim.
Its interesting that the radio went out last year (its a '91) meaning that was its 10 year life was over
Ryan
SHOcago Web site
AIM "Shoman594"
[This message has been edited by Shoman594 (edited 01-12-2002).]
