Rack and pinion
Boochy47
Michigan
Hey fellas Machanic is replacing rack and pinion 2500 for everything even reprogram and labor and alignment what you guys think?
kryptto
South East, Florida
Looking at Alldata - All the part alone without labor is - OEM - $1700 and listing approx 6+ hours labor - plus alignment. Sounds fairly on the mark.
Boochy47
Michigan
Ok that makes me feel better, I thought he was trying to bend me over a barrel and show me the fifty states
Boochy47
Michigan
I’m about to buy those mrt muffler axel backs instead of corsa now due to this 2500 dollar repair lol
kryptto
South East, Florida
I am glad for you those MRT was a month of me tooling around forums and YouTube I really like the sound they make. Not raspy and that rap rap rap. My only issue.... Not black tip option.
kryptto
South East, Florida
My daily driver is my wife's old ScionTc it has 165k and the transmission went. Couldn't find a remanufactured - and the price is what they told me was a used one with 37k from somewhere in GA - that shipped in ran me $3100. I had an external oil cooler added - changed motor mounts and new master cylinder that was slowly failing $5k
The car is worth $2500kto a kid who wants it.
Prices are nuts...
Majestic
Those tips will be black after about 200 miles. Lol!
kryptto
South East, Florida
ROFL - with Catless... You are 100% correct - my bad.
2014 Ford Taurus SHO PP - Catless Downpipes - 3BAR MAP - Ford Performance Spark Plugs Colder Range - K&N CAD, Reisch 170, HP Tuned, Accel Coil Pack, Chrome Delete - Android Auto Nav System
9a6b349a4c3294968b511c6d6c99913d
Boochy47
Michigan
Hey fellas now my active parking lines arnt working right anyone ever heard of this?
Boochy47
Michigan
The reverse cam turn guidelines are messed up not accurate at all I’m hoping it’s not messed up bad idk how much it would be for dealer to diagnose it for me but I gotta fix it it drives me crazy I was hoping someone would know on here what too do
kryptto
South East, Florida
I assume the mechanic disconnected a sensor or accidentally:
Removal and Installation
1. Remove the front lower air deflector.
2. Disconnect the electrical connector.
3. With a suitable tool (such as a flat-blade screwdriver), gently pry the retaining tabs to remove the active park assist sensor(s).
- Remove the active park assist sensor(s) from the front bumper cover.
4. To install, reverse the removal procedure.
After installing the sensor(s), use the scan tool to verify that the active park assist sensor PIDs responding correctly. Carry out the Azimuth System Check See: Collision Avoidance and Parking Assist Systems > Procedures > Azimuth System Check. If the parking aid sensor does not respond correctly, refer to Active Park Assist See: A L L Diagnostic Trouble Codes ( DTC ) > Diagnostic Trouble Code Descriptions > DTC Charts in the Diagnosis and Testing.
I have Forscan however not home and can't check the PIDs. You will need to gets the DTCs
Sent from my SM-T860 using Tapatalk
bmytych
