Rack and Pinion replacement/help
Masonxmoral
Colorado Springs
Hey all, hope everyone is safe and healthy! I recently went to Brakes plus (closest place to me) after replacing my PTU. I originally went to get an alignment, but they said I had a bad rack which would not hold an alignment. They said it had a bad bushing causing up and down movement. When I go up a driveway I can definitely hear what that would sound like, but I’m looking for advice if this doesn’t sound like what a bad rack would sound like or do, or if they’re trying to squeeze some money out of me. I’ve seen a couple of videos on youtube of what to do and it does not look all that hard, but one video showed reprogramming it and all that, which I have no clue how to do. Should I have it professionally done? Should I do it myself? Thank you!
Shadow351
Hilliard, OH
What year is your SHO? By bushing, do they mean the rubber isolators where the rack mounts to the subframe? 'Cause for my 2010 those are like $70 (there is an upper and a lower, each are about $35) where a steering gear is over $1000. (see #3 & #4 here https://www.tascaparts.com/auto-par...e/steering-cat/steering-gear-and-linkage-scat) I don't know of any other 'bushing' that would affect alignment. The rack itself (the part inside the steering gear) is usually just a metal bar with teeth on it that interlock with a gear on the steering shaft, and 4 'ball' joints (which are replaceable) inner & outer tie rod ends.
ticoscen
Just found my 2010 SHO PP has a cracked Rack and Pinion main housing.
It is cracked between the steering gear and the inside casting after the mounting bolt on the drivers side. I mean, it's cracked around in a circle like a broken glass straw. Man.... was working on my CATALYIC converter and took a close look at the rack housing.
When someone turns the steering wheel right and left, you can see it open up about 1/8".
Thought I could epoxy it but decided to order a replacement unit. I hope they accept the core back! The damage is hard to see when it's static. But, prying up on the housing with a screw driver showed subluxation happening because it was broken clean and all the way around! Jeez!!!! :)
(Last of the damage to fix from my hitting a tree at 15MPH due to black ice)
Explains my recurring dream about the car losing control for no reason. I guess my guardian angels were telling me to take a closer look at the rack before catastrophic failure occured. Thank you!
Boochy47
Michigan
Just spent 2500 on stearing rack and pinion and tie rods n alignment and now my active parking lines arnt working right I noticed
