Without the radiator sight shield, you can check a couple of other things to determine the refrigerant type:
1. Look on the tubing to and from the accumulator/drier canister (rear of engine compartment along firewall, towards passenger side strut tower). If there is a yellow "non-cfc" label on it, then you use R-134a.
2. The tubing to and from the A/C condenser (the condenser is in front of the radiator, the tubing is by the radiator filler tube), as well as the tubing to the compressor should also have the yellow labels.
3. The A/C compressor clutch from the factory is gold in color for R-134a systems. BUT, that might not hold true if you have a remanned compressor.
If there aren't any labels you MIGHT have R-12, but I don't believe there were any Taurii in '93 that used R-12. If you don't find any labels, I'd have a A/C shop take a look at it before you try anything...
