quick sensor question
Sounnder
Lompoc, Ca
I have replaced the rubber hose and re-installed the line, but for some reason, I havent been able to locate the harness. Im also not sure what sensor it is.
Any help is appreciated. 120K Service is almost done. :boink:
Irish Pride
Irish Inside
MusicCityUSA
It's a coolant temp sensor that keeps the EATC from coming on until the temp is at a certain level. The pigtail is very similar to the one that goes to the steering rack. Make sure you didn't plug it in to the wrong sensor.
-Chad
Greg Corcoran
Denver metro area
-Chad
The official name from Ford is the CELO (Cold Engine Lock Out) switch. Mine is non functional, as the heater comes on immediately even on the coldest Colorado days. Of course it blows ice cold air for the first 3-4 miles... I have been unable to find a new one. Anyone know where I can get a new one?
zoomlater
Seattle, WA
this one?
Irish Pride
Irish Inside
MusicCityUSA
I'm pretty sure it only came as part of the pipe. Look online for a replacement pipe and it will come with the sensor.
-Chad
BaySHO Performance
SF South Bay
this one?
No. That one goes into the coolant housing attached to the rear cylinder head. It tells the PCM when to turn the fan on.
Greg Corcoran
Denver metro area
this one?
Nope. CELO switch not the ECU sender. They are located in different pipes but are within a few inches of each other.
BaySHO Performance
SF South Bay
Don't know if the CELO switch only came with the pipe itself. I personally doubt it but may be wrong. Would be called something like inlet tube w/ cyl. head tab to heater core.
Sounnder
Lompoc, Ca
Well for anyone who is interested, here is the connector that connects to the CELO switch.
Yeah the old reliable stuff is not coming up with anything.
Doug at FPS used to grab parts and stock them when chain supply was low (seals, crank sensors, etc) but this was not on the frequently repaired list for SHO's back in the day. You can always call or email FPS and ask.
It really looks like used is going to have to do unless you get really lucky.
Sounnder
Lompoc, Ca
I will second that you should email SHO Source. He has some used parts not listed on the web pages. He was able to hook me up with a replacement center timing belt cover from parts he had.
