Quick Question...
skippie
Monroe , MI
I know someone out there knows the answer, but before I buy them, I wanna be sure...do the 3.0L plug wires work on the 3.2L engines also? I would like to know, because they are about $40 cheaper, and Im wondering why.. eek!
Mr Anonymous
Tire Wall
The 3.2 coil pack is mounted at a steeper angle than the 3.0, so the wires for the 3.2 are a HAIR longer. The 3.0 wires will fit, but 1-2 of the wires might be stretched a little tight. If you leave those wires out of the plug wire holders on the valve covers, they fit just fine!
Yes, they can be made to fit just fine. Don't leave any slack in the rear bank wires and make sure there is no interference with the coolant lines under the throttle body. I ahve not had to leave them out of any of the wire looms. An added benefit is that the 3.0L wires have the cylinder number printed on them.
