I did a brief search and couldnt find my answer so...
I had to pull my crank bolt to swap the lower timing case. When I put the pulley back on, what tool do I use to make sure the pulley is center while going on? I know I had to use that puller tool to get it off, is there a tool to put it back on as well? (i ripped her apart like 2 months ago and i dont recall if the pulley will just slide back on since I used a tool to remove it)
Thanks in advance.
Thanks in advance.
:theyareontome:
