Quick Clutch Questions.
SASHO91
Zoom Zoom
San Antonio,TX
What was the (EDIT: had a brain fart...)clamping force of the GenI clutch( 9.25'')?
Also, Was a different flywheel used for them? From what i can tell it seems as though the clutch is smaller and still mounts the same way a 9.75'' clutch mounts. Allthough maybe the dowels are positioned differently.. :shrug: (like they do much)
The pro's seem better with an aftermarket 9.25'' clutch then a stock or stg.1 clutch w/ the 9.75''. pro's being~~cost, PP's, materials, weight(im assuming there), and life span. BUT thats riding on how much the holding capacity was on those clutches. So i could be beating a dead dog... but i want to make sure... also, I remeber reading a few threads about questions like this, but a search could not bring them up. :shrug: I do know that a genI clutch on the 9.75'' pp will increase the capacity though... but thats besides the point....
TIA.
SHO#7
Cincinnati
It's the pressure plate that gives the clutch clamping force. And IMHO if Ford did a recall because the 9.25 was so failure prone. Your 91 should already have the 9.75, why would you want to move down in size. The weight is not a good answer, because you can get a lightweight flywheel for the 9.75.
SASHO91
Zoom Zoom
San Antonio,TX
uh....yes you are correct... but with the smaller disc you have less area... getting the idea???
Yes i know they did it on the STOCK clutch... yes i know my 91 has the 9.75''.. i listed the reasons why i wanted to..... i wasnt implying it that way. i meant that it weighs less than a 9.75'' clutch.. (im assuming there also.)
If the AFTERMARKET clutch holds 90% more(you know which one im talking about now, dont ya...) that *would* be more than a stock clutch,no? if not close to a stg.1. again, assuming that its lighter, thats just another plus. and not that big of a deal if its not. PLUS the fact that it has wider straps and a better disc, only puts it up at the top of my list. AND!!! ( :lol: ) its less than a stg.1 clutch...
thats why i want to down size...
But like i said, this all depends on the clamping force of the 9.25'' clutch... which was my question.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
When the "upgrade" was done, Everything within the bell housing was replaced with a larger unit.
The flywheel, PP, and Disc were all "upgraded" to the 9.75
SASHO91
Zoom Zoom
San Antonio,TX
Thanks Kenny.
Just with that, it may not be worth it.. allthough a new flywheel never hurt no-one.
TYSHO
Earth
You can get lightweight pressure plates from SPEC, they run $79 over normal cost. SPEC can even customize your disc size for no additional cost. So, you can get a lightweight 9.75" style PP with a 9.25", 9.5", or 9.75" clutch disc.
thatSHOguy101
