1badsho
Not even sure if i called the part correctly but this is what i need.
I am getting real close to put the motor that I have been restoring back in my 90 sho
Question I have is the black lead and red lead that goes from starter/battery terminal over to the starter relay on the drivers side fender. They are bolted by a 14 mm nut i believe.
Best I can explain it ... question is ... which cable goes where ... does red sit on top and the ground on the bottom or vice versa... took the motor out a mth ago and forgot !
