Cheapsho,
Please do yourself a favor and;
1. pinpoint the leak - clean up the area you suspect and watch for a fresh oil trail.
2. If you determine it is a camshaft seal leaking - use the "special" tools recommended, or be very, VERY, VERY, careful not to nick, scratch, or burr the camshaft while trying to remove the old seal. A nick, scratch, or burr will destroy a new seal in a short time!
I have used self tapping sheet metal screws, screwed into the seal, to pull or lever a seal out of its position. But again, be careful not to nick, scratch, or burr the camshaft or the bore the seal fits in.
Apply grease to the part of the seal that goes around the camshaft, and a light coat of sealer to the surface of the seal that goes in the bore.
I like to use anerobic sealer for this, but it is expensive. A litght coat of RTV (sensor sensitive) will also work.
Good luck on finding and fixing your oil leak, rangerj
