Quarter Panel Removal
JaredJHuffman
Grand Rapids, MI
I posted a while back looking for parts for my busted-up green '95 ATX.
I found a tail lamp, the trim piece that goes underneath it, a trunk lid w/spoiler and center tail light, and various other little pieces at a junk yard on a green 94 taurus (with a better paint job than mine :S). All of this cost me about 50 bucks!
I would also like the right rear quarter panel off of that car, but the owner doesn't allow torches out on the lot. If I can find a way to get it off the car, he will sell (give) it to me for 30 bucks. Does anyone have any bright ideas or tricks to remove that section of the body without a torch?
-Jared J Huffman
projectSHO89
SHOless In St L
See if they'll let a cordless recip saw in. Sounds like they just don't want power tools in the yard.
Steve
SHOWYA
TurboSHO Member
Houston, TX
That junk yard should be able to cut the part for you. I know they do it in my neck of the woods but im not sure if they charge you for cutting it off.
JaredJHuffman
Grand Rapids, MI
Thanks for the help everyone. After arguing with the owner over the phone for a while, he has stated very clearly that he will not allow anything but chisels and hack saws for cutting. It looks like I hafta find the panel at another junk yard.
blacklabel
Hartford, WI
Just take in a battery operated dremel with a cutting wheel for metal. :cool:
If you use a good one they should be able to cut many things, if you turn the speed up high enough.
JaredJHuffman
Grand Rapids, MI
The most badass battery-operated dremel still only gets 35000 rpm. I have tried using these on sheet metal in the past, and it will take approximately 3 years of cutting to get the panel off and an entire hardware store full of cutting wheels.
SHOracer86
Florida
The best thing to use to do it is an air powered cutting wheel. I did both of my rear quarters with it and tach welded it in.
Mr Anonymous
Tire Wall
Um, yeah there's gotta be more than one junkyard in MI, and the quarter is common to all '92-'95 Tauruses so it shouldn't take more than about 2 minutes on http://www.car-part.com to find what you need.
NJSHO
Clean Your Shorts!
NJ
dont let him see the torch/tools, whats the worst that could happen, you get asked to leave the yard?
JaredJHuffman
Grand Rapids, MI
They actually search you on the way in. When I went before, I tried to sneak a little propane torch in for loosening bolts, but they found it and made me walk it back out to the car. :D
I think I should be able to find another taurus laying around.
