Putting on an Idler pulley (between alt & WP)
WILL SHO U
Sooner or later
Home of the Indy 500
Is it just bolt on or is there something special I have to? Mine is missing and the A/C locked up so someone rerouted the belt and removed the idler pulley. Anything else I should check for since its been running this setup for over 6 months (that I know of)?
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Did they remove the entire bracket or just the idler? Should just bolt in.
socialdeviat
Ca
Make sure you get the right one. Theres two there on an ATX, Both have different depths due to the bracket. The pullies are identical but the spacers and bolts are different.
93rev2sev
Hockeytown
Does anyone have a picture of the correct routing? I don't have an ATX so I can't look on the emmisions tag.
WILL SHO U
Sooner or later
Lower pulley
Just looked its actually the lower idler pulley. Does it come off in pieces or is it all one. I have to get it used because ford discontinued it.
