pbgsho
Both my 90 and 93 SHOs have been sitting for about 6 years. Both are running well but need help with the brakes. Is the simplest and cleanest way to remove old fluid to open a bleed valve at one of the wheels and pump the old fluid out? I tried to suck it out of the master cylinder but access is is blocked by the sensor reservoir.
Since I have a Thexton Teves 4 exchanging the fluid in the abs pump will not be a problem since I can cycle it and then pump the old fluid out.
Thanks,
pbgsho
Thanks,
pbgsho
