Purging Old Brake Fluid
pbgsho
Palm Beach Gardens, FL
Both my 90 and 93 SHOs have been sitting for about 6 years. Both are running well but need help with the brakes. Is the simplest and cleanest way to remove old fluid to open a bleed valve at one of the wheels and pump the old fluid out? I tried to suck it out of the master cylinder but access is is blocked by the sensor reservoir.
Since I have a Thexton Teves 4 exchanging the fluid in the abs pump will not be a problem since I can cycle it and then pump the old fluid out.
Thanks,
pbgsho
Phoenix
SHOHOLIC
QC , Canada
I would open all 4 bleeders , let gravity do its job. Refill and bleed , remember that bleeding a sho can be a *****.
SHOtimer
#2910
Santa Clarita, Ca
