jayro
Started pulling the engine in my "94 mtx this afternoon. Pulled coolant hoses coming off the top and bottom of the radiator. Also the two going through the fire wall. Drained trans fluid and popped out the axles. Took off MM bolts. Removed hood and intake (just to make it easier to get at stuff). Removed shifter from trans. Removed y-pipe. Will be detaching fuel lines at the rails. My question is about the electrical. I know there are some to detach on the trans from when I replaced my clutch. Besides that, what am I looking at? Are there just a few to unplug, or a bunch? Located in a specific area?
Also, do I have to do anything with the power steering pump/resiviore ect?
This is the first engine I have pulled and I want to make sure I'm getting everything. Anything that I missed? Thanks
