HI all
I used this checklist at the bottom, that ArkanSHO put on another thread...
Now my question is about the struts. Those were never mentioned in the list. I went ahead and and unbolted them from the towers. When I go to put them back in, what procedure should I use? I have never messed with struts/springs before. I am figuring that I will have to get a spring compressor to put them back in. Right? This whole job of pulling the motor took alot longer than 4 hours...ALOT longer....but it was the first time around. Anyway, it's done. Now I have to pulled the head to see what damage was done from the spun cam sprocket. Thanks for the list and any other help!!
As for line by line, let's see if I can do this without looking at it:
Disconnect and remove battery
Disconnect Yellow #6 wire to Mega-fuse
Remove internal floor steering shaft boot.
Disconnect steering shaft at steering box with 10mm pinch bolt above second floor boot.
Disconnect calipers, hang out of the way
Disconnect exhaust system ****** at flex-pipe (grind bolts off is easier up north)
Remove front splash pan between bumper and subframe
Disconnect ground wire to starter.
Disconnect positive wire from starter
Remove lower bolts (4?) from bellousing
Remove 4 torque converter self-locking nuts
Break loose four 18mm sub-frame bolts
Remove headlihts then front bumper cover (access to real bumper to lift from is handy), don't forget to disconnect marker lights and signal leads.
Remove intercooler, Vortech, mounting brackets, blower oil feed lines or other intake up to throttle body and cables
Remove radiator hoses from engine
Disconnect coolant reservior line
Disconnect PS line from reservior to pump
Remove heat lines behind and below EGR
Remove tranmission shift cable
Disconnect large square wiring harness plug above transmission
Disconnect sping-lock fuel lines at fuel rail
Remove passenger side windshield cowling or loose knuckle flesh on next step
Disconnect ECU plug (held in place with 10mm bolt)
Disconnect brake booster and small vacuum line from back of expansion chamber
Disconnect ground from alternator to fireall
Disconnect plug below and outward from ECU plug connected to Eveporator system
Disconnect transmission and power steering lines on drivers sides of coolers
Either evacuate and disconnect AC feed/return lines on compressor OR remove three bolts holding compressor to engine and suspend with coathanger as close to radiator without fan as possible.
lower car onto 4 x 4's or landscaping timbers without the wheels of course.
Remove the 4 subframe bolts
Lift car slowly while watching the AC compressor clearence and looking for overlooked wires or hose connections
Think that was all of it.
