GrolarBear
- Joined
- Jan 10, 2017
- Messages
- 38
- Reaction score
- 13
Spring of 2019, my 2012 SHO got yanked out of a parking space by a tow truck improperly, both WRT that it shouldn't have been towed, and it was pulled out dragging the back tires out of the space. After that, I had a noise that was intermittent and we (me, a Toyota Tech friend that both heard it and drove it, and a dealer that I talked to but never managed to hear it) thought was the PTU, but after a few weeks of me trying to get it to the dealer to hear it, it just went away and never came back.
Anyway, I decided to do a PTU fluid change (If it's just sludge then it's good, if there's any chunks I need to dig into this more). I added a drain plug and only a few drops of very thick sludge came out. I know I debated pouring some Kerosine through it to clean it out (in the fill, out the new drain), I don't remember if I dared to, and I did 2 fluid changes and drains to clean it out (only got sludge, no hard parts, nothing metallic at all, nothing that would stick to a magnet) and decided that after the next oil change or 2 I'll swap it again and then do it every 25-30K miles. Filled it with RP Max Gear 75w-140.
I decided that I'm changing the oil, trans fluid, and PTU fluid this weekend. I have no signs of leaks anywhere on the drivetrain with only a little bit of greasy build up on the top of the transmission fill cap and the cap on the vent tube at the top/back middle of the engine. I opened the PTU drain plug and only got dripping out of it, maybe a total of 1/2 a cup if that.
Where the heck is the fluid going??? Is it possible it's going into the trans case somehow?
