PTU drain plug size?
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Does anyone happen to know the specs or the part number for the SHO PP drain plug?
Went to change mine for the first time a few weeks ago and the drain plug is completely stripped out. Going to need to use an EZ Out on it and want to have a new one ready to go in its place.
Talked to my Ford Rep and they had no clue...
FiveLeeter918
Tulsa, OK
Ford rep said the best they could find was 1/4"-18 NPTF, but unsure if that's the PTU or the diff cover...
SilvererSHO
50 miles north of Minneapolis, Minnesoder.
HUH? The plug is over .800" in diameter and has a 3/8" square drive. It should be 1/2" NPT based on the .800" plus OD but I haven't confirmed that. Don't know how it could be stripped out. I've had mine out probably 15+ times on both of my cars. And it's a fill plug, not a drain. It has to be sucked out.
EDIT:
Do 2013+ PP's have a drain plug or is it because it's an updated PTU that it has a drain plug?
xFallenxCripplex
Pp have drain plugs I've seen some places they fill in the vent tube.
I haven't been able to confirm if there is a fill plug as well as drain couldn't get far enough in till I ran out of time or stripped the bolt on the cat right when I got copper anti seize :(
Sent from my Pixel 4 XL using Tapatalk
PP's have both a drain and fill plug. It is easier just to fill through vent.
SilvererSHO
Well I'll be damned. I've done quite a bit of reading on them and I don't think I've ever seen that mentioned before. Obviously my 2012 PP doesn't have one. I do put 4-6 ounces down the vent tube before I drive 100 yards or so to my shop and then suck what I can from the fill plug. I then fill from the vent tube and let a few ounces of excess run out the full plug before sealing it back up. I've gotten pretty good at accessing the fill plug so adding a drain plug isn't worth it to me personally but it would still be nice. If mine ever craps out I'll either get one with a drain plug or add one before putting it in.
FiveLeeter918
Tulsa, OK
EDIT:
The drain plug on 13+ PPs is a 1/4" hex
Johnbigdog
michigain
FiveLeeter918
Tulsa, OK
