Seraphim.312
Chicago
So my SHO was giving me some trouble over the weekend where as I was accelerating there was a loud knocking sound coming from the car and it sounded like it was coming from the driver side front of the car. The knocking would get worse as I would turn the wheel.
I decided to take my car to a Ford dealership for inspection and the mechanic called me back saying that it was the PTU.
He said that I needed new tires because the current tires I had on the vehicle made the computer read a certain way and because of that it would affect the PTU.
I've never heard of tires affecting such a mechanical part of a car before. I recently just bought this car and all the tires match as a set and are brand new so I would believe that this guy is trying to scam me in buying the tires.
Does anyone know if what this mechanic is saying is factual? I can't find it anywhere on Google unfortunately.
Ta2dResqr
Central Ohio
I cannot think of any reason a set of matched tires would affect the PTU. Provided they are all the same size and about equal wear, they should all spin at the same speed (except when turning, or slipping) and should not be an issue.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
For a long time I ran 245/40 in the front and 275/35 in the rear, slightly different rotational speed and never had any issues. One of those things that to me seems highly suspect, depending on where you go…the dealership will try to sell you a dream if you are unsuspecting.
Shadow351
Hilliard, OH
Yep, Get a second opinion. Mismatched tires might cause the computer to over-actuate the clutches in the RDU, but the PTU is basically a 90 degree gearbox, it is completely mechanical.
Seraphim.312
Chicago
Can you elaborate?
Seraphim.312
Chicago
So in that case tires shouldn't affect it that much right?
RoketRdr
Houston
Correct. Like what was previously posted the PTU is nothing more than a mechanical reduction gearbox off the transmission. No way mismatched tires can affect that. The RDU and trans would be a different story.
SeanDev
Tires can greatly affect the PTU, always make sure you have same tread depth or within a 1/10 on front. Different sizes on the front causes the PTU to turn at different speeds on each side. Not good for the PTU. Reason why AWD is recommended to have tire rotation every 5,000 miles. Plus if your tires are not OEM size, it's a good idea to change the size in the cars computer, easily done with forscan. And if your hearing knocking, especially backing up or turning, look at your sway bar link. When the ball joint goes out the link will make a knocking sound. When the PTU is going out it will sound like rocks in a coffee can. I know all this because its all happened to me at least once. Ford owner for 32 years.
Seraphim.312
Chicago
I guess what I don't understand is tires wear out eventually anyway. Is this car not conditioned to function properly even when the tread starts to wear? I guess that just sounds a little weird to me for a car to do. It was definitely a knocking/clanking sound and the car would shake a lot between giving it a little gas and breaking.
SeanDev
Tires can greatly affect the PTU, always make sure you have same tread depth or within a 1/10 on front. Different sizes on the front causes the PTU to turn at different speeds on each side. Not good for the PTU. Reason why AWD is recommended to have tire rotation every 5,000 miles. If you do not have OEM size tires, you can change tire size on the cars computer, forscan makes it easy to do. And if your hearing knocking, especially backing up or turning, look at your sway bar link. When the ball joint goes out on the link it will make a knocking sound. PTU going bad will sound like rocks in a coffee can.
It's all about the revolutions per minute when it comes to AWD tires. If the car is doing that while your breaking, definitely have someone look into the suspension or cv axle on that side. Passenger cv axle has a carrier bearing that holds it due to its length. Your symptoms are not good either way, and I personally wouldn't drive a vehicle that was doing that.
shoster207
