This is from Josh's web site on camshafts.
As a primer, here are the measured specs of the stock cams:
MTX Intake 0.348” Lift, 205° Duration @ 0.050”
MTX Exhaust 0.328” Lift, 201° Duration @ 0.050”
ATX Intake 0.328” Lift, 201° Duration @ 0.050”
ATX Exhaust 0.328” Lift, 201° Duration @ 0.050”
The ATX Intake chain ****** is also advanced 4 crankshaft degrees relative to the MTX cam. As the Intake chain ****** is what drives the Exhaust cam, this effectively advances the Exhaust cam in an engine with ATX cams by 4 crankshaft degrees, which also reduces the overlap by 4 crankshaft degrees. Compounded with less duration on the ATX intake lobe, there is substantially less overlap with the stock ATX cams. In total, there is 6 crankshaft degrees less overlap, 4° due to the advanced exhaust cam, and 2° due to 4° less intake duration (1/2 of the total duration difference). Note that if you are regrinding cams, it is critical that both intake cams be either MTX or ATX, or you will have mis-matched exhaust lobe centerlines between banks due to the 4° difference between MTX and ATX exhaust cam timing, as driven by the intake cam flanges. We carefully check each set of camshafts to verify that we have matching intake cams for each set of cams made.
Thanks Mr. Joshua!!!:wave:
