So within 2 hours of using the auto headlights for the first time in years really, my turn directionals stop working. I had recently taken my aftermarket fogs off because one bulb burnt out and its impossible to change the bulb with them on the car. I just taped up the wires and left the switch off. My friend told me my outer brake light was burnt so i switched the bulb with the one right next to it, not having a replacement, and hoping the directionals didn't work because that bulb was burnt. It doesn't seem like the bulb is burnt though because the same light didn't work again and the "bad" bulb works fine in the other socket. I ordered a new multifunction switch hoping it's that, does that make sense to anyone, the 4-ways still work fine too. Does anyone think that using the autolights or taking the fogs off could've caused the problem and does anyone else have a fix other than changing the multi-switch? Thanks
