Hi guys,
I'm having a problem with my 1995 ATX SHO. The car will not start always, but I have found an odd pattern to the starts. The car can sit all night out in the freezing cold and start up fine first try in the morning. Now, if I were to drive the car a bit, shut it off and try to turn it back on, the car has problems. It will crank but no start. After some time and tries, if I apply the gas pedal, the car will start. If the car starts this way, however, the tachometer will not work for a good 10 minutes. Eventually it kicks on while driving. If the car were to then sit for hours, it will start up fine. This problem started in the winter (I'm in CT.)
Anyways, this is very annoying (gas stations are especially bad) so I brought it to a local garage to check it out. The guys here know SHO's (most of them own or have owned one) and they cannot find the problem. They replicated it, but spent spent hours trying to diagnose it and are coming up with nothing. They said at one point the codes returned a bad EGR valve but they know that's not the problem. They also ruled out the starter. So the car is coming back to me, problem still occuring but not fixed. Any ideas?
