I own a '94 SHO with the ATX. My problem is that my rpm's are at zero and my check engine light is on, but the car still runs. I replaced my CPS(crank position sensor) thinking that was it, but no go.
However, when I unplug the battery for a bit and plug it back in the rpm gauge works for about a mile or so then it drops to zero and the check engine light comes on. The car doesn't ever stop running. It is difficult to start at times, but that's it. Once it starts it doesn't quit.
Do you think my water pump is leaking and soaking my crank position sensor? I don't see any leaks on the ground.
Thank you for any help you can give me. This one's got me stumped!
Chuck
Chuck
