Problem Installing Gen 2 Oil Pan
stoessjc
Woodland Hills, CA
Does anyone know a trick to getting the rear forward nut on when installing the oil pan on a Gen 2 ATX? Can't get a straight shot at it to get the nut started. At this point, ready to leave it off and hope it does not leak. Any help is much appreciated. John
AREA 91
PA SHO SHOP
Area 91
I believe I used a 1/4 inch drive rachet with a 2 extensions and a universal joint.
stoessjc
Woodland Hills, CA
Thanks. I tried a 3/8 extension with flex and a 1/4 extension without flex and not luck. Tried a grabber, still no luck. It is very tight and angled, making it hard to get the nut threaded straight. I will try the 1/4 flex. John
