Hey all;
I'm looking for someone experienced in wiring the SHO into other applications to help me with a few questions, if you don't mind.
I'm getting ready to try and wire my SHO out of a '92 mtx into my '90 probe LX. The probe originally came with a vulcan 3.0. Probe wiring diagram can be found here http://forums.probetalk.com/showthread.php?t=1701298756 (adobe required). I'm pretty sure the diagram for the 3.0 is around page 99-100. My idea so far is to reuse the probe ircm, since I'll be tying into the probes cooling fan, and main fuse box. I'm also using the probe transmission.
Could someone give me a hand in figuring out which wires require special attention from the sho ecu? I don't see any labelled vehicle power on the probe ecu, and the closest I could find is the pin 1 labelled room fuse. I'm assuming that probably means it gets power via the room
fuse in the fuse panel? I noticed there are 3 seperate pins on the SHO PCM labelled vehicle power. I believe they are 1,37, and 57. Can I tie the room fuse wire into pin 1 on the sho, and just splice off that wire for 37 and 57 as well?
Also, any idea which pins I should be running to my ircm from the PCM? Any and all help is greatly appreciated, as I'd really prefer not to toast a PCM or icrm. Thanks!
