Preventative maintenance ?
tompumped
VT
When I do my clutch should I replace my rack and p/s lines?
Should I sell my LUK and get a Hi revs jr. instead w/ ceramic tob? Should I worry more about the diff pin ejecting if I go the other way.
Car has 110k, I think the tob is eating the fingers.
Will still get second, but I rarely do that.
Mr Anonymous
Tire Wall
Not unless they are leaking or not working properly.
What don't you like about the LuK clutch and where exactly do you plan on buying a Hi Revs Jr. since AFAIK they haven't been available for several years???
99% of people are fine with a stock-equivalent clutch. The ceramic TOB is definitely a sound investment.
SuperHO
Mental Patient
St. Joe, MI
no question...get the ceramic TOB. and unless you're planning on heavily modding it in the near future, :stupid: oem clutch'll do ya right fine.
tompumped
VT
I just wanted a little more bite. I was going to buy one used, but someone else got it anyway.
I thought the main reason for the tob problems worn out clutch fork pivot bushings. I was going to buy the teflon ones from shonut and just use the regular tob.
The only issue I had with the rack others on here have also. When it was cold outside before the car warmed up, there was a tight spot just off center in either direction. I posted and a few other people have the same issue. I tried flushing the fluid and I don't think it made a difference.
Nothing seems to be leaking, I haven't had to add fluid. I'll just leave it for now.
thanks guys
tompumped
VT
One more question. I was considering taking apart the trans to install new roll pins for the diff pin, and input seal. I was thinking of welding it, but I don't want any adverse affects, plus I honestly think it takes a lot to throw a pin. I beat the living snot out of my first sho and it took a long time to eject the diff pin.
I have rebuilt a couple t5s, i'm pretty confident I could complete the job if it's recommended. Any special tools needed? As always the advice is much appreciated. .
I read you can check the pins by taking an axle out, what do I look for. When I looked the last time I saw one pin that goes all the way through and the other two are two peices that stick out a little, if that makes sense:)
I was going to buy the shshop clutch because of what I read about clutch strap breakage also.
