Zap
Hey everyone,
Can anyone tell me if Pressure Plates usually come oiled/papered in any way to prevent rusting? The guy who machined my flywheel told me to use brake cleaner on the flywheel surface before putting everything back together, and also unless they used a special paper, the pressure plate would most likely be oiled for the same reason and to clean its mating surfaces off. Any truth to this, and does anyone know what Josh @ SHONut does as far as his parts go? I have the NEW clutch "kit"
Also, what should I use to clean the outside/clutch "inside" area of the MTX?
ALSO: I was told to use my old PPlate bolts, since Ford apparently discontinued them. I know I need about mediuum strength (Blue?) Loctite. Will this be OK?
Thanks,
Chris
<small>[ July 11, 2003, 08:56 AM: Message edited by: Zap ]</small>
Thanks,
Chris
